Rubber seal
Column 2 piece collar/clamp
Firewall pad
Believe the seal goes against the firewall, but does the clamp go between the pad and seal or over both...???
I didn't remove the '68 column I'm installing in my '67 but I remember that the seal was at the bottom with the 2 piece slide on clamp next. I would think the firewall pad would be on top of all that and not pinched between as it wasn't on other pieces bolted to the inner firewall (brake pedal support, etc.) it was on top as if it was put in last.
Jon
Seal should directly contact the firewall and column/mounting plate should not touch pad
So the pad should be cutout larger than the mounting flange of the collar?
Please!
I am using a repro that has a hole just big enough for the column.... another fine after-market product!
What format can you send? Or is it old school hard copy?
