Need a bit more information. Is it a factory tach? What type of ignition (points)? Pictures help!
If the tach has failed electrically, the engine stops with the ignition wire hooked up like that. For example, if the rally pac was stolen, car would not start.
A stock tach does not connect to the negative side of the coil. Instead, the 12v power source flows through the tach, through the pink resister wire (#16A) to the connector at the firewall for red wire (#16) and to the coil's positive side. If the tach fails the coil doesn't get power (except when starting and the tach & pink wire are by-passed by the white wire from the starter solenoid. EDIT; the negative side of the coil is connected to the distributor.
Modern tachometers are "three wire" and connect to the negative side of the coil (plus 12v and grd).
