1 - 2 of 2 Posts
Does anyone know if you can take a 1968 Tilt Away system , install directly into a 68 non tilt car and use the column as a TILT only system? Simply plug in main wiring harness and forget the rest- vacuum , cables, etc?
Thanks ahead of time.
The simple answer is yes. I tracked down all tte part and restored a tilt away system. I installed it in my car and love it. The tilt and tilt away functions are independent. If you don’t hook up the tilt away actuator and wiring it will have no affect on the car. The tilt functions will work just fine as they are built into the column top knuckle and controlled by the turn signal lever.
1 - 2 of 2 Posts
