1 - 19 of 19 Posts
Does any one know how to reset the miles back to 0 on the upper numbers. I cant not get the dail out. Not made like a standard face. Has a rubber bushing holding it, I did remove the locking clip. but still will not come out. 68projectcar
Discussion Starter #2
Any info will help, I just dont want to break something. restoring car, If I cant get it, I will have to send out to have done.
The upper 5 digit number you are referring to is the odometer and is not intended to be reset. Why do you want to reset it? The lower 4 digit counter is the trip odometer.
747782
Because I have restored the car from the ground up. I want it to show O miles on the new drive train.
Difficult to do by design. I suspect that it is illegal in most cases. When replacing a failed unit, I don't know if it's legal to change the replacement to match the old, or if the legal process is some sort of paperwork that would be attached to the title.
Resetting it requires pulling gauge out. Turn it over. Been a long time. unhook center metal shaft the numbers wheel rides on. Spread numbers apart as they have "teeth", then rotate as needed.
Many years ago I had to replace my orig speedo cluster as it was rusty, bad shape. When I got another orig type, I needed to rest that one to my orig miles.
So in my case, I did the right thing. So there can be a ligit reason.
Discussion Starter #9
Hey, Thank You, I will try that. I know it can be done, I have done many on my other Mustangs, But the trip ometer housing is made different from the standard housing. I will try, THANKS
Did you see the video on this other thread last week?
I haven't done it but it looks like you've just got to pop the clip off and remove the whole dial from the gauge. Assuming they're similar year to year of course.
Discussion Starter #13
The video is on a standard speedometer, The trip meter is not the same, made different. Yes I removed the locking clip, shaft with the numbers will not come out, no room to move back and forth.
Discussion Starter #16
Great, Now how did you get it out. I know how to reset the numbers, I just cant get it out of housing.
1 - 19 of 19 Posts
