My thought on heater hose routing is as follows:
Manifold through spacer with vacuum valve attached between spacer and hose termination at core connection closest to centerline of firewall. The other hose goes from the water pump terminating at the outer core fitting at the firewall. My core connections are side by side, not top and bottom. I would also like to where the lone hose is supported. Is there a bracket at the valve cover or clip ion shock tower? Would appreciate an answer to this or pictures are golden. Thanks in advance.
