Nive car but I've never seen an "Original" with exhaust exiting through cutouts in the rear valence.
Also, what is that keyhole looking thing in the rear quarter just in front of side maker lamp? Alarm?
Also :
Missing Smog
Hood Pins incorrect
I see alot of rust in the usual areas
Drag Pack car (based on horn location)? Missing Drag Pack?
http://home.netcom.com/~jonescha/Photos/DCP_0355_178x109.jpg
"If you're under control you're not going fast enough"
Parnelli Jones
Try my website
Your observations are generally correct, but the location of the horn doesn't necessarily mean there was an oil cooler. My 1969 Boss, which did not have the drag pack option, has the same setup with a double wiring harness on the passenger side, where both horns are mounted. There is also an unused wiring harness on the driver side, and the horn mounting holes have never been used (although calcruzn's obviously were). I read somewhere that both horns on '69 Bosses were factory installed that way to accomodate the drag pack option, even if it wasn't ordered.
