Hi,
While returning from a Mustang Club meeting the other night someone mentioned that my '69's left brake light was out. I figured the bulb right? So when I got home I pulled the bulb and it checks good. Turns out there is no voltage at the socket for turn signal, brake light or emergency flasher. Tailight is working fine. There is no power in the harness at least to where the wiring loom disappears into the wheelwell. All the other lights are working okay. They're all on the same fuse so that's not it.
So, anybody got a suggestion as to what I should be looking for? Do all three functions go through the turn signal switch?
Thanks,
Rich
If they are wired like the '66, it all goes thru the turn signal switch in the steering column.
