Had a little discussion with a club member on the 351W heads.To my knowledge the 2V & 4V engines designate the carb application & the heads are the same on both motors.The 2V had dished pistons & the 4V had flattops with valve reliefs to gain the extra compression.Is this far from the truth?
Greg
Never go into a battle of wits unarmed!
http://albums.photopoint.com/j/View?u=1589603&a=12101731&p=45958396&Sequence=0&res=high.jpg
Regards From the Great South Land.
I'd say you squatted just about in the middle of it Greg...*G*
IME, I have not seen any discernable difference in those heads....
The basis for my race car engine is actually a '69 4V W....I still have the original heads sitting stripped on the shelf in the shop....
If there's anything you need to know about them, just ask...
Pat
Thanks Pat,this bloke's a Legend in his own mind,so I thought I might re-arm before the battle!"G"
Greg
Thanks for asking that one. I have a 69 M code Mach and had the same question about a year ago but never asked. I have to locate a 69 block since mine had a 74 Windsor in it when I got it. going back original. I still havent fired the new engine up, but that was one of the little nagging questions still up in my head. BTW, where in the Great South Land are you, there are a few of us down here, I'm near Jackson Mississippi.
Later
ssscode
No, he said GREAT SOUTH LAND
not Mississsissipissppi *G*
Australian Nat. Concourse
http://albums.photopoint.com/j/View?u=1584152&a=12055089&p=46900022&Sequence=0&res=high.jpg
http://albums.photopoint.com/j/View?u=1584152&a=12055089&p=46927241&Sequence=0&res=high.jpg
Any body I know ?
I'm a little further south,here in sunny Queensland,Australia.If you need to know anything here, fire up the keyboad & good luck with your engine.
They say "Rome was'nt built in a day"........but we were'nt on that job!!"G"
Greg
