I recently R&R'd the rear window for a headliner install. What is used to fill the gap around the new window seal on the exterior of the car? I vaguely remember removing some sort of hard flexible material from this area when I was removing the remains of the old seal. What was that stuff and what can I replace it with? Thanks!
Johnpro, thanks also for the headliner install tip about using the wires on the front bows in the existing holes at the front. Worked like a charm. I think that was your tip if I recall.
BTW, I used long zip ties instead of wire. Worked good also.
