The first knucklehead who tried to paint my car cut the wires to my door panel lights, I have another harness (somewhere). Do the light harnesses simply unplug somewhere under the dash? Same with the switches in the door jamb, he broke both of them too. I can't believe how much this guy screwed me......
yes, about 6 inches inside the door jam, you will find the wire connector, just follow the wire coming out of the grommet
The light harness unplugs about 3 or 4 inches in ..you still have to remove the screw holding the the ground wire behind the kick panel. Pop the switches out and unplug them at the back of the switch.
Discussion Starter · #4 ·
thanks guys!
