1 - 2 of 2 Posts
'69 fastback.......in black primer,good fenders, good doors except one corner on the drver side has a rust hole, hood is bent(still usuable but not sure it could be fixed) have 2 new quarter skins(one is installed but done very poorly), tailight panel and rear valance also new but put on poorly, trunk needs drop offs on both sides, has mach 1 instrument panel and clock, 2 passenger side mach 1 seats, fold down seat, has 2 new front floor pans but they need welded in(instead of using screws and caulking), 8in w/4.11's and a mini spool(center section is out and gears need put it), new hardware and shoes in the back, battery in the trunk with 0 gauge wire, power steering, manual drums(new master cylinder and a few hard lines), has manual tranny pedals, B&M rachet shifter, comes with a c6 and a 3sp, new clutch, alum. bellhousing, block plate and all the clutch linkage ,torn down 351c(have alt. brackets and pulleys, also 302 headers, brackets, and pulley), aluminum radiator(needs custom mounnts), all the glass is good, no heater box, has chrome 15" 5 spoke wheels(look like torque thrusts)w/ OK tires, bolt-in frame connectors, 1 hood hinge is locked up and needs replaced.............email me if interested....ill try to get some pictures to put up tonight.
1 - 2 of 2 Posts
