Is there a brace or cross member that connects the shock towers together running under the oil pan? If so does anyone have a pict?
There is a bolt in crossmember directly under the oil pan, most folks call the engine crossmember or #2 crossmember.
It's essentially a 2" diameter tube with the ends flattened and a hump that curves downward to clear the oil pan.
It's attached to the frame using special bolts that can be purchased from AMK.
I have the cross member off my '69, if you need one. Left over after the TCP R&P install
Randy
I also have one if you need one. Came off of a Mach1 I parted out.
Ductman
