1 - 2 of 2 Posts
I have seen lots kits to convert to new style non sealed beam headllights for 65-68 Mustangs but I can't find one for a 69 Mustang with the 4 headlight setup. Has anyone seen or used one of these kits for a 69? If you have, are they better?
There are tri-bars available for about $75.00 each (or more if you go to Mustangs Plus). As well you can go with Hella The part numbers for the lamps are 71156 (High-Beam) and 71456 (High/Low-Beam) and these are about $49.00 each. You will need two of each. These are the ones that come to mind immediately...I've even used 5.75" round size motorcycle headlamps (slightly modified from 86-87 Suzuki GSXR's) with good results. There are options out there...unfortunately, none of them are very cheap.
1 - 2 of 2 Posts
