I recently installed a C4 transmission in my 69 Mach 1 w/ a 351w and was using a FMX before. I hooked up the FMX linkage as best as I can, but it feels off when I move through the arch on the shifter.
My question is if this shifter will work for this application?
Thanks.
yes, your shifter will work, but, you may have to bend the arm just a little. The transmissions are a little different. Just put a couple of bends in the arm, to take out the arm feeling a little too long.
When you say arm, are you refering to the rod that connects the c4 to the shifter or the shifter?
