howdy, i have a holley 4bl on my 351w mach1 any way the other morning i got on it rather hard and now the carb seems messed up[idle,popping noise in the exhaust,black exhaust and very rich]any ideas what i have done and how to fix..thanks
Did you check the choke?
Does it idle really rough and try to die? How is the fuel pressure on the carburetor side of the fuel pump? Sometimes a sudden surge in engine RPM can shoot the fuel pressure high enough to bend the mounting tabs for the floats, opening the check valves continuously. This was a constant problem on the old 68 GT390 with a Holley 4150 4V carb, at least until the addition of a fuel pressure regulator and a new front float. Your problem sounds a lot like the one I had.
