1 - 2 of 2 Posts
1969 Mustang Convertible 302 T5
Recently pulled and reinstalled motor. Convertible top motor not working. Found this wire under the hood but attached to the starter side of the relay. I suspect it is the power line for the convertible top but someone put it on the wrong side of the starter relay. I'm still new to this, but I believe the post that this wire is attached to only gets the voltage when the key is in the starter position. I'm not with the car and need to advise someone remotely. Can someone back me up that the convertible top motor gets hooked up to battery side of the starter relay? With that much info, I'm sure we can troubleshoot and figure this out.
741348
You are correct, the wire needs to be put on the left side. The only wire on that side should be the cable going down to the starter.
1 - 2 of 2 Posts
