Hello,
I have scoured this forum, as well as others to determine the issues I'm having with my gauge cluster and have come up short. Please save me.
My vehicle is a 1969 Mustang Sportsroof 302. It has a non-tach dash. Currently all exterior lights, driver footwell light, key light, and dash high beam indicator light work. My speedometer, alternator and oil pressure gauges also work.
None of my gauge cluster lights (except the headlight indicator) work, and yes, I have tried turning the headlight switch knob, and my fuel and temp gauges do not work.
Steps I have taken to fix the problem:
The gauge lights are the biggest issue because I can't see my speedometer at night. With it being winter like 75% of my driving is in the dark, and I've had to mount my cellphone flashlight to see my speedo. The cooling system is brand new, and I can time fuel stops by mileage, so I can live with those being out until I have time to test the sending units. I am under the assumption that the gauges being dead is an electrical issue, as they both have absolutely no life. To my knowledge if it's a bad sending unit the gauges will still move a bit.
I'm at my whits end on this one and at a total loss for what to do, so I would appreciate any and all help you may offer.
- Replace the headlight switch
- Verified and cleaned the contacts on the headlight switch plug
- Replaced the dash circuit board
- Replaced all of the dash lights with LEDs
- Replaced all of the dash light sockets
- Replaced the fuel and temp gauges
- Covered the metal on the gauge mounting area for shorts/grounds
- Tested grounding both black wires at dash plug pin 8 separately and together
- Tested grounding black wire at dash plug pin 11 (youtube video recommendation)
- Cleaned all of the contacts on dash plug
- Replaced fuses and cleaned the connectors
- Replaced the dash Constant Volt Unit
- Replaced the high-beam floor button
