Beach Bum
My 69 Coupe has the roof mounted dome light which I do not care for & want to eliminate when redoing the interior, I was thinking of using the Fastback side panel lights in the Coupe panels by the rear seat, my question is for the fastbacks did the power for those side panel lights still come from the wire that ran to the dome light spot on a Coupe?, or did they run from a different spot?
if your going to do that i say go ahead it should look neat just post pictures when you are done.what i think you should do is pull the wire for the dome light down into the spot you want it in the quarter area (its attached to the tail light harness and should be in that area anyway) cut it and split it and run another wire through the trunk area or package tray to the other side and conect it. it would work fine and alow you to do what you want
