Gas pedal: natural
E-brake:
assembly = natural
pedal = dipped in semi-gloss black up to where it meets the assembly
release lever bracket = dipped in semi-gloss black at an angle so that there is a small triangular natural area natural at the very end.
Pedal Support = natural (but ford service replacements were black)
Brake pedal = dipped in semi-gloss black to just below pivot point.
For natural finish, I just bead blast the parts and clear coat them with a satin clear. Note: if you have a parking brake warning light (just below the ignition) you have to make sure that the ground strap that bolts to the e-brake assembly touches bare metal.
