69 SCJ questions
486 Views 3 Replies 2 Participants Last post by  ang67must
regarding 69 cobra torino SCJ////////////////// NOM 390 is in there. it has C7AE-A heads 4 bolt pattern ' but' the exhaust manifolds are 2 bolt. cant get to cast # can someone tell me application of those heads? are the 2 bolt exhuast manifolds (as i suspect) correct for the car? do torino R codes have a 2 bolt pattern head?
[email protected]
[color:green]www.ang67must.com</font color=green>
· Registered
C7AE-A are 390 GT heads used on 67-68 Mustangs, Torinos, Cougars....
Original an R code would have thesame exhaust manifolds as a Mustang . Can only guess thay whomever put the engine in didn't get the manifold with the heads and dumped the other manifolds in. CJ manifolds will not fit without some modifications to the heads. C7 heads should have 4 hloes on each end port and 2 for the centers
Hope this helps
Jeff Speegle
MCA Shelby Gold Card
www.geocities.com/MotorCity/6473/
Mustang & Shelby research, documentation, and help.
Where sharing with one .. means sharing with all
