After rebuilding everything but the brake booster, my brakes aren't hitting until far down in the pedal travel, and then they are real grabby (will lock them up without a problem).
New stainless steel brake lines, neither I nor the local shop find any leaks. Tried swapping out the master cylinder, a bit better but not much. Bench bled the master cylinder both times, but I may still have a bubble trapped.
Feels the same whether vacuum is applied to the booster or not.
Rod was adjusted to just start pressing the MC piston when bolted up.
Any thoughts?
Carl
Any thoughts?
Carl
