·I had the same problem. Part of the issue is the new weatherstriping you're probably using. I too can't stomach closing my doors with the glass all the way up. If your door panels aren't on, you should be able to adjust your door channels/door glass to do exactly what you want it to. It allows for a pretty decent amount of adjustment. Good luck.
70 Mach 1 (351C 4V 4-speed) I've been restoring since '96. 95% complete. Also have a '68 HT (289 2-speed) that I restored between '97-98 and is FOR SALE! The VMF has proven to be an invaluable resource for information, humor and excellent advice.
