Does it hang under steering column or does it go along next to the shaft where it bolts to the dash frame?
Got pics or drawings?
Finished my Painless install, EVERYTHING works!!
The rod goes down the top center to the switch its self. Which is on the topside near the floor and the turn signal should lay flat covered by the collor.
I mean the wiring itself, when it connects to the main under dash wire harness. what route does each harness take to get to the under dash connectors.
I believe there may be room to fit it in between the column dash brace (where the column bolts to the dash frame) this would hold it up and not interfere with the plastic column cover that hides the internals.
There was a flat flexable band off the mounting bracket that wraps around the loom and holds it up on mine.
