I checked my wiring manual. I don't know about the grill lights, but from what I can see, the marker lights should have +12v on one of the wires at all times.
The other wire is grounded by the emergency flashers and the turn signals - the grounding completes the circuit. The wirring harness runs along the driver side and has connectors at the left driver side kick shield, and inside the trunk or rear seat area. The license plate lamp is powered by the same 12v source. Thus if it is illuminating, your problem goes back to the grounding which is in the circuit I described above. I don't think from what I can see, this has anything to do with headlamp switch.
Tom
