I have a 70 302 and need all the engine brackets and pulley snumbr sif thre out there. I tried mustangtek.com and found a few but I wanna see what people say. Especially the PS bracket plate.
Thanks.
70 302 w/PS w/o A/C
Which pump are you going to run??
There are 2 different pumps, One having a Female pressure port, other Male port.
The Cradle bracket is different for each. No Numbers on either.
The Flat steel will be the 70 302 bracket as the 351 won't work.
Pulley will be a DOAR A
Dan @ Chockostang
Yes i need the part number for the flat steel bracket?
And if anyon has numbers for these pulleys
70 302 w/PS w/o A/C
Crank Pully?
Water Pump Pulley?
Alternator Bracket Numbers?
