the one I ordered 25 yrs ago, which i assume is the same thing, fit perfect and looked almost identical if not exact
i since removed them when i had the car painted.
Reactions: Lawnjockey
Yes, I installed the same part from NPD on my 1970 Mach 1. My car didn't come with louvers from the factory, so I had to drill the holes. The instructions were pretty clear and, although there was a pucker factor, it all worked out well. In my case, I think I installed the upper hinges just a bit too low. Be aware the top of the louvers should completely cover the rear glass.
The fit is very good and overall so is the quality.
Thank you gents. I feel more confident ordering it now.
LJ
Same on my 1970 good fit. I put lower catches a little to close to the vents. The catches need a a little spring stretch to hold down tight enough so they don't bounce loose.
