1 - 10 of 10 Posts
I bought some 1970 spindles on ebay and want to confirm they are indeed 70 spindles before I order my brakes. can anyone hook me up with the dimensions?? I cant find them with searching to save my life!
Thanks!
The easiest way is find out the casting number between the ball joints.
1970 Spindles are one year only with D0ZA-3107- and D0ZA-3108- Casting numbers
Does anyone have a ford parts interchange book? I thought some mavericks had the same spindle in later years. Those may have a different cast number.
If the number changed, they were different in some way. Might not matter. You could use D1ZA spindles on your car and never notice the difference.
Are they drum spindles or disc spindles?? -- drum and disc spindles will interchange from 1970 to 1973. What are the casting #'s? If you need some casting #'s info I have a decoder book. Post the #'s on them.
71-73 drum type have a more massive steering arm than 70 type, otherwise identical.
Exactly, Drum Spindle, or Disc Spindle as horsehead has already shown Numbers. The 3108 is Driver by the way, 3107 Passenger.
Post numbers we will all help you in your quest.
Dan @ Chockostang
Discussion Starter #10
perfect! thanks guys
1 - 10 of 10 Posts
