I am selling the remainder of my 71-73 parts assortment that I have gathered over the past years. There is a Number of NOS items included as well. All Costs PLUS SHIPPING!
INTERIOR ITEMS:
STEERING WHEEL:
1.Very RARE Factory Leather Wrapped DELUX 2-Spoke Steering Wheel, Black with Black DELUX Horn Pad and Trim, NOS Center Emblem 250.00
CONDITION: Has worn area between 11 o’clock and 1 o’clock, (or 4-7 o'clock) Has small split in leather at 3 o'clock, but overall in VG condition.
2. NOS 2-Spoke center emblem D3ZZ-3649-A 20.00
3. USED Black Dash Pad, VG/EX Condition 50.00
4. Anti-Rattle Clips for Dash Board, Attach to Metal Portion of Dash 2 @ 10.00 each
Very hard to find item, as most are broken or lost when removing dash.
5. 2-Spoke DELUX Horn Pads USED; 1- Blue with Center PONY emblem VG/EX 40.00; 1- Black with no emblem, 25.00; 1- Black with “Ford” emblem; 25.00.
6. 3-spoke Rim-Blow Steering Wheel, Usual crack at 12-4-6 and 9; does have working horn switch with wire cover. A decent core or rebuild if you are skilled ;35.00
7. NON-TILT Mustang Steering Column, Black; has newer working FORD turn signal switch, and ignition cylinder and key; 35.00
8. FORD Tilt Column, NOT SURE of Year/Model have had for 20+ years; black: 50.00
9. 3-Spoke FORD Steering Wheel Pad, Possibly LTD or Crown Vic, Black VG: 25.00
TACH/SPEEDO CLUSTERS
10. WORKING Tach and Speedo with Tripometer; EX lens, circuit board, voltage regulator and harness; ALL Lights worked when tested 05/05; 195.00
11. WORKING Tach and Speedo with Tripometer; LENS has piece MISSING at top of fuel gauge, aprox 2” long, down 1”; EX circuit board, regulator and harness, ALL Lights worked when tested 05/05; Can Swap Speedo and use Repro Lens! 150.00
12. WORKING OIL/ALT/TEMP Gauge Cluster; ALL in EX Condition, INCLUDES Harness; ALL Working properly when tested 05/05; 75.00
13. Delux Instrument Cluster Bezel and Matching Passenger Side Bezel. ALL seems to be in order, they have not been repainted, chrome trim is faded but still looks great, CLEARLY defined surround of each gauge and dash pad trim. VERY NICE pieces 75.00 pr.
14. NOS FORD Instrument Cluster Voltage Regulators; P/N C9AZ-10804-A; CORRECT for SHELBY, MACH 1, and ALL 69-73 MUSTANGS; 50.00 each 2 avail.
INTERIOR ELECTRICAL
15.PERFECT CONVERTIBLE TOP POWER SWITCH: (May be NOS, I can't remember, no box) Very Clean, NOT BROKEN OR MISSING CONNECTING PINS! Worked when tested 05/05. EXCELLENT and VERY RARE to Find THIS NICE! 195.00
16. NOS FORD Intermittent Wiper Switch D1ZZ-17A553B (SW994) PERFECT 100.00
17. NOS Replacement Ford Intermittent Wiper Switch, E7TZ-17A553-A, 50.00
18. USED Intermittent FORD Replacement Wiper Delay Box, Worked when tested 05/05; 50.00
19. 2 speed used wiper switches (2) each worked when tested 05/05; 10.00 each
20. DELUX Interior MAP LIGHT, Clean and Working when tested 05/05; 20.00
21. DELUX Interior Front SEATBELT WARNING Harness and BOTH Ratcheting Seatbelts (no buckles), COMPLETE date code 39-72; Black; 75.00
22. Radio Bezel with attached AM/FM/Cassette Radio; Working when tested 05/05; good sound, Radio Shack Brand, 25.00
23. Used STANDARD Speedo Cluster, needs cleaning, not broken, all there, 64K on odometer, Working when tested 05/05; 10.00
EXTERIOR ELECTRICAL ITEMS
24. NOS Junction Block, Mounts under hood, near Battery and Voltage regulator; Black P/N D0SZ-14448-A; USED ON SHELBY, MACH 1 and Convertible as well; 30.00
25. NOS FORD Positive RED Battery Cable D1PZ-14300-D from Bat to Solenoid; 20.00
26. Reproduction FUEL SENDER UNIT, mounts in Gas Tank; 25.00
27. NOS MOTORCRAFT Radio Noise Suppressor, Needs minor Cleaning, green wire with Stainless Connector, P/N D1ZZ12300-A Great Show Item! 50.00
28. USED Under-Hood Lite, (NOT UNIVERSAL STYLE) needs cleaning, but all there including wire loom and bullet plug. Worked when removed from car 05/05, no Bulb at this time; 30.00
29. USED Trunk Lite, (NOT UNIVERSAL STYLE) with ALL parts in very nice condition, including wire loom, bullet plug and mounting clips. SOCKET is near perfect, white with clean silver mounting tab and bulb. Works. NO CUTS OR SPLICES; 45.00
30. USED Trunk Lite (NOT UNIVERSAL STYLE) with a white clean Socket, silver mounting tab, bulb, wire loom, but wire has been cut. Have taped correct bullet connector to wire so that buyer can correctly repair to personal specs. Tested and Works 25.00
31. USED Trunk Lite (NOT UNIVERSAL STYLE) with a white clean Socket, silver mounting tab, wire loom, bulb, but has “Clip Style” plug. May be for Cougar or T-Bird. Tested and worked 05/05; 25.00
ALL ABOVE LISTED TRUNK LITES CAN BE USED AS UNDER-HOOD LITES
73 MACH 1 Grill Lites and Bezels:
32. A set of Clear Grill Lite Lens and Housings with Bezels; Need to be re-conditioned but not broken or damaged; 25.00 all 4 pieces
33. Reproduction Center Emblem for same; D1ZZ-8213-B; 20.00
34. NOS FORD Trim Clips for the same Grill; 22 pcs D3ZZ-8B251-A; 20.00
35. USED Parking Lamp Lens Sponge Gaskets; 6 pcs, 2.00 ea or ALL for 10.00
Miscellaneous Interior Items
36. NOS FORD Front Window Rollers (Squared Off, not Round). Used to keep Door Window Glass Tracking properly. Round ones tend to pop out and allow window to rattle back and forth in regulator track. 2pcs, 15.00 ea; 25.00/pr
37. NOS FORD Remote Mirror Bezel/Nut; Attaches mirror remote to door panel; P/N C7SZ-17B732C; 3 pieces 10.00 ea, ALL 3 for 25.00
38. USED Rear Quarter ASHTRAY and Holder; LID IN EX Condition, Snaps Closed, Ash Cup has surface rust, no holes, not painted. Very Nice! 20.00
39. USED but EX Condition, A/T Shifter Lever, near perfect Chrome, VERY CLEAN, with shifter bulb holder, NO PITS, DINGS OR GOUGES, 50.00
39. Used Black DELUX Shifter Handle w/Chrome thumb button; hairline crack on back side of handle, easy repair, or use as is. A nice interior upgrade. 20.00
40. NOS FORD A/T Shifter bezel P/N D1ZZ-7D443-A 60.00
41. 2 USED Convertible Sun-Visor rod assemblies, Pitted, but NO DAMAGE to LATCH AREA, easy clean up for re-paint or chroming; 40.00/pr
42. NOS FORD Radio Knobs, Round, with Black Camera Case center insert, NOT A MARK ON THEM; P/N D1ZZ-18817-A; GREAT SHOW PIECE 25.00/pr
43. NOS FORD DOOR PANEL GROMMETS 4 pcs total, Stainless with blk felt insert; P/N D0AZ-6221999-A;15.00/pr; 4/25.00
44. USED Radio/Heater Control Bezel VG/EX Condition; 10.00
45. USED Gas Pedal STAINLESS TRIM from A/T Car and Matching E-Brake trim. Both pieces in EXCELLENT Condition; 25.00/pr
46. USED Seat-Back CHROME Lift Handle; 1 Only; “L” Shaped; EX Condition; 10.00
MISC DOOR PANEL ITEMS
47. 2 USED WHT DELUX INTERIOR Door panels; VG Condition with BLK Door panel cups attached (had been painted wht at one time, some remnants). Door Panels have mounting holes on outer edges. Had been mounted to doors with Stainless Finish Screws and Washers. 50.00/pr
48. Door panel clips, 24 pieces for Standard Panels; 10.00
49. NOS FORD Window Crank Handle BACKING PLATES; CHROMED, P/N C9ZZ-6523370-A; 6 pcs in bag 15.00/pr or ALL 6 for 30.00
50. NOS FORD Window Crank BLACK Plastic Backing Plates, (fit beneath above Chromed Plates) 2pcs/bag; P/N C8AZ-6223370-A 7.00/bg 2 bags available
51. Reproduction Window Crank Stainless Insert Discs (Cover mounting screw); 5 pcs available; 1.50 each or ALL for 5.00
MISC CONSOLE ITEMS
52. USED Black CONSOLE LID, EXCELLENT CONDITION, Very Slight wear; NO BURN HOLES, SPLITS, RIPS or TEARS. 30.00
53. USED CONSOLE CLOCKS (2 available) Working when tested 07/2004, but have not been checked since, no way to verify. BOTH in VG/EX Condition, one has mounting washers/bushings 35.00; one without 30.00. Lens and Housings in VG/EX Condition
54. Misc Console pieces, Fair/Good Condition; Ashtray Lid, has been painted black; Ashtray holder, Console lid hinge; Console box, has 6 screw holes on bottom, easily covered with piece of felt, good latch pin; Shifter/Clock Bezel, screw hole on left side of shifter bezel, can be repaired not cracked or broken, clock bezel OK; ALL ITEMS 25.00
MISC EXTERIOR ITEMS
55. USED Rocker Panel Trim, Stainless, GOOD Condition, Solid piece W/O Black Painted Inserts; 25.00/pr
56. USED Hood Scoop BEZELS AND NOS INSERTS; VG/EX Condition Primed and ready for your mounting pins and paint 100.00/pr.
57. NOS FORD Door Mirror Gasket P/N D1ZZ-17724-B; 10.00
58. USED Remote Mirror Assembly (Green) with Ex Glass, No damage to housing or mounting points, includes cable, mirror nut and washer; knob to remote is broken but easily replaced. OVERALL VG/EX Condition 50.00
59. NOS FORD Rocker Panel Trim Mounting Clips 10 pieces; P/N D1ZZ-6510182-A and 4 used clips; 14pcs total, 20.00
60. USED Convertible Rear Bumper Fillers; (Green) L and R side; VG/Ex Condition, NO SPLITS or Rips; 20.00/pr
61. USED Front Side Marker Bezels, EX CONDITION, NO BROKEN MOUNTING PINS, L and R side, Primed and ready for Install; 20.00/pr
62. NOS FORD Rear Tail Light Lens Gaskets (Housing to tail light panel); P/N D1ZZ-13520-B; 30.00 each or 50.00/pr
63. USED CHROME Rear Bumper Guards; CORRECT FOR 71-73 MUSTANGS and COUGARS; 2 sets, one pair with mounting hardware VG Condition; 30.00; one pair without mounting hardware 25.00. ALL Rubber strips intact, not torn. 50.00 both pair
64. Used Rear Decklid with Rear Wing Mounting Holes, no rust no dents, underside red, top side in grey primer, includes Hinge mounting brackets and bolts. 50.00
65. USED PASS SIDE DOOR SHELL, VG Condition, no visible damage or rust holes; RED with BLK Mach 1 Stripe, 30.00
ALL PRICES PLUS SHIPPING. Will ship via UPS or USPS, depending on size. Cash, Bank Money orders only.
Reasonable offers considered for multiple items purchased.
Discussion Starter #2
Items sold: #'s 3, 8, 38, 52.
Items # 1, 10, 11, 12, 15, 16 and 18 are posted on ebay with pics. Thanks, Paul
INTERIOR ITEMS:
STEERING WHEEL:
INTERIOR ELECTRICAL
MISC CONSOLE ITEMS
MISC EXTERIOR ITEMS
Do you still have the steering column?
