Hi,
Where would be a good place to find spare parts for a 66 8 track tape player?
Would a 73 Mustang tape player offer any interchangable parts?
Thanks,
John Thomas
Hi,
The 66 8-track player was made by Motorola and the '73 variety was most likely made by Philco as Ford bought them several years prior so they're probably not very compatible internally.
I checked my schematics cache and I don't have one for either radio. :(
What parts are you looking for? There are places out there that sell belts if that's what you need.
Hi,
Thanks for the reply. I don't need a belt, but there is an internal component with some corrossion (maybe a transformer or something like that). It is about a 1 inch square that is wrapped with fine copper wire, there are 2 or 3 of them in the bottom rear, right corner of the player (looking at it from the front).
The radio playes great, but not the tape player. The 8 track motor turns, and the tracks change, but all that comes across the speakers is hisssssss, and some static if I jiggle the tape.
If you have any tips, please let me know. I can send you a picture via e-mail if that would help.
I've seen troubleshooting guides on [censored], but I've never been lucky enough to win one of the auctions on those.
Thanks for your time,
John Thomas
The component you're describing is either the power supply filter coil or the output transformer. Considering the radio is working these are probably not the problem.
The 8 track and radio use the same amplifier/output so you can rule out that section too. The only things left are the parts of the 8 track before the amplifier.
I never had the pleasure of working on one of these beasts but the thing the next thing I'd check are the heads. Try to find a vintage electronics forum and ask how to do some basic checks. They'll probably have some tips to isolate the problem by touching components with a screwdriver or your finger.
If you do need new parts (and not just a cleaning/lube) you can try to hunt down the SAMS Photofact for this radio (try ehay) and that will give a breakdown of all parts and the part numbers from various manufacturers.
