Hello,
I have a 66 Mustang 8 track tape player. The AM radio plays great. The 8 track tape player doesn't. The motor turns, the tracks change, but the only sound is a "hhhiiisss" through the speakers.
Does anyone have any troubleshooting guides or information about these players?
Thanks for your time,
John Thomas
Most common problem is a broken drive belt. I've picked them up at electronics supply houses.
Hello,
The drive belt is intact and functional.
Thanks though,
John Thomas
Try denatured alcahol to clean the head,,,if that does not help,,,then service is required. I have serviced a many of those,,,,most were just very minor troubles,,,,switch-engagement troubles,,dirty heads,,belt,on the rare ocasion,,a bad transistor in the pre-amplifier area of the tape playback.
Sounds to me like the head might be bad.... try cleaning as suggested earlier. If that doesn't produce results take a small metal screwdriver and gently touch the leads connected to the back of the heads while also touching the blade and you should hear a loud hum through the speakers if so this indicates the tape preamp is good and the heads are bad. Hope this helps.
