Yes. With the 5.5, I get a little tire rub inside the wheel well on big bumps - passenger side only due to the design of the cars, but not on the fender lip. My car is also lowered a bit. The 6 should fit without any issues. Hope this helps.
I have 6.75" backspace on 18 x9.5 on my 67. It has a rear disc brake kit which required and 1/2" of backspace so if your running drums in back 6" would probably be just right.
Looking into piecing together a basic underdash A/C system for my 68 coupe using a Mark IV type evaporator. Vintage Air has a nice reproduction unit that Summit has for $300. There are also many cheaper underdash evaporators on the market.
https://www.summitracing.com/parts/vta-672001vhy
I...
All,
Mocking up the exhaust system n my 67 coupe and thought I would pass on some key findings:
1. JBA 1650 Headers for 289/302: These could not fit better or be more well made. They clear the frame, starter, T5, and cable clutch set-up with room to spare. Highly recommended. Thick 1 piece...
Hello Everyone, just wanted to start a post as I am about to start my Edelbrock Performer Heads, Howards Cam, Lunati Roller Tie bar roller rockers, Edelbrock RPM Air Gap and Tri-Y upgrade. I might come back to this post to ask questions. Here is a picture of all the parts and gaskets I have been...
Hello everyone. I recently started restoring 1967 mustang coupe. after almost finishing it, I noticed the car was sitting uneven. sitting 1 inch low from rear driver side and 1 inch low from front passenger side. I was going to change springs and shocks in the front either way and i got them...
Another upgrade question, this time about installing power steering. I have found the kit for around $900 or so, but kit does not include crank pulley. Where do I get the pulley, and if later I add A/C will I need yet another pulley? I guess I could do a electric PS but that is around $1400...
