I am almost positive but I just want to make sure that a 3rd member from a 68 stang 9" will fit in a housing from a 66 stang 9". I know the housings are different, but the pumpkin is the same right?
Tim
Dont forget, the axle spline count has to match too. I wouldnt expect you to have a 31 spline center in a 68, but if someone swapped it, you'll need axles to match.
And not to forget the pinion yoke. Several different U-joints could be used in a Mustang 9"...
Also a short and a long pinion yoke.
