1 - 20 of 36 Posts
Were Mustangs the only cars that used the necked-down 9" housings? And, if so, how many years used them? And is this one of those?
762529
Since the factory 9 inch in my 69 M1 has one, I'd say at least 65 to 70. Don't know about 71-73.
The early 57-59 housings had a taper tube. Forget which years.
I’ve got an early 9” (57-59) in my 65 and it doesn’t have tapered tubes. Maybe it was a small/large car thing? Mine is a small bearing rear end.
Reactions: RTM
The 9” out of a ‘73 Cougar had reduced tubes and 28 spline axles.
762560
'65/'66 were the only years where the tubes necked down about 6" from the flange. The spring perches were located in the necked down area so smaller u-bolts were used.
Many 9 " rear ends neck down about 2" from the flange but they use full size u-bolts.
Discussion Starter #9 (Edited)
Were the 9's put only behind Hi-po's? I can't see them putting them behind an A-code. The reason for all of my curiosity is that there is one for sale locally. I figure that even if the only real benefit is a better ratio, for what he's asking, I can't even buy a steeper chunk. Looks like all that was offered in a 9 was 3:00 and bigger. Currently running a 2:79. There's also the potential for a bigger brake package. Sell my clean, painted 8" and perhaps break even.
Yes, the 9" in '65/'66 Mustang was standard equipment with the K code and was not available as an option with any other engine. Since it was only in the K cars there is a limited quantity of them out there.
That being said, you can cut the axle tubes out of a '65/'66 8" and weld them into a 9" center section and create your own version of the unique K code 9".
If the axle bearings are the same size, the brake packages can swap between the 8" and 9" axles.
I've seen 9" gear ratios in 2.80 and lower in newer model cars for fuel economy. Think late 70's to early 80's big cars. Mercury, LTD, T-birds, etc
Sent from my SM-N960U using Tapatalk
Here's what I have. Round back side with the dimples. The tubes taper down but not by much. I did have an identical housing that did not taper. For some reason the leaf spring pads are not in the correct spot on the housing I have.
Discussion Starter #17
Is there a part number stamped anywhere on the housing that will tell me what it was in originally?
No. But the length from flange to flange is a dead giveaway.
Or you could just buy a reproduction 1965 or 1966 Mustang 9" axle housing. Both are available.
1 - 20 of 36 Posts
