·I replaced the yoke on my 9" and may need to re-do it because of the slop in the crush sleeve. Is this something I can get to while everything is still in place? Gears were 100% fine before replacing the old busted yoke...so I just need to get the sleeve in and torque it up properly. Just not sure how buried that crush sleeve is...
1) remove yoke, slide out bearing, then sleeve...then reverse
- or -
2) remove pinion housing then get at it that way - or - ::
3) take the whole pumpkin out and deal with it off the car
