1 - 14 of 14 Posts
I've been shopping around for a GT40 or GT40P engine for my 65. I have a wrecking yard telling me that they have a 1996 5.0 from a Mustang. My research tells me that the 5.0 was not available in a 96 Mustang, but the wrecking yard insist that that's what they have. I'm going to look at it Saturday.
Is there any chance a 96 Mustang could have a 5.0?
From Wikipedia...https://en.wikipedia.org/wiki/Ford_Mustang_(fourth_generation)
In 1996, Ford dropped the 302 CID Windsor V8 that was in production since 1968[12] and introduced the Modular 4.6 L SOHC V8. These engines were produced at two different plants, Windsor and Romeo. A "W" in the VIN 8th digit indicates a "Romeo" engine, while an "X" indicates a "Windsor".
The Windsor and Romeo have subtle differences. Valve cover bolt patterns are one. Romeo has fewer bolts than the Windsor. Another difference is the front cover bolts. The Windsor uses 8 mm and the Romeo uses 10 mm bolts. The Romeo uses jack screws on the main caps and the Windsor uses dowels. The new engine produced 215 hp (160 kW; 218 PS) at 4400 rpm and 285 lb⋅ft (386 N⋅m) of torque at 3500 rpm, matching the output of its predecessor. For 1998, the 4.6 L V8 received a small increase in output, resulting in 225 hp (168 kW; 228 PS) at 4750 rpm and 290 lb⋅ft (393 N⋅m) of torque at 3500 rpm. This was achieved through PCM calibration and a modified fuel system. Though capable of matching or exceeding the older 302 V8's output, the 4.6 L V8 was criticized for delivering inadequate performance, particularly against the larger displacement of the OHV V8 used in the Mustang's chief rival, the Chevrolet Camaro
Administrator
There is a chance but it shouldn't be unless someone is mistaken about something. Like it's actually a '95 or something.
Running around somewhere around here there is a 1996 Mustang with a 1966 427 engine in it. I own two vehicles that aren't supposed to have 351W's in them but do. And one 1986 Mustang that isn't supposed to have a 5.0 in it but does anyway. You never know until you look. If you're not too familiar, Google up pictures of a 1995 Mustang 5.0 engine compartment and a 1996 4.6 to get an idea of what to look for.
It would not come from the factory with a pushrod 5.0 from the factory. However that was 23 years ago, who knows what PO’s have done?
totally agree. I have a 1996 Mustang GT which I purchased new. That was the first year of the 4.6 motor in the Mustang. I think one of two things happened--either the person on the phone is mistaken or someone swapped the 4.6 motor for the 5.0.
Externally, one of the differences are the tail lights.
Back when these were newer, tail light swaps were common.
It wont be a GT40 though. It was rated at 215HP, 10 down from the Fox body, because of the T-bird intake.
I kept the intake on my swap, fits a 65 well.
Discussion Starter #8
The price is right, so if it's a decent 5.0 I'll get it. Hopefully my next question will be which cam does it need.
Thanks.
Discussion Starter #12
I took a look at the engine and it's 1986 Mustang engine that's been transplanted into a pickup truck. It has what looks like a smog carb instead of fuel injection. I can't see any advantage in going with this '86 5.0 engine for $400 vs a newer GT40P other than the exhaust issue.
Are there any redeeming qualities to the '86 5.0 engine that I don't know about?
Administrator
Nope. Equipped with what are widely considered to be the worst performance heads Ford ever put on a small block if it is stock.
nope ,get an Explorer GT40P
1 - 14 of 14 Posts
