96 5.0 with a 4.6 T5 trans. Will this work in a 65? I know there is some with longer I put shafts and with lower throw out bearing forks etc etc...Just looking for a little help on this..Thanks
64 1/2 D Code Coupe,
I am using a T5 from a 94 V6. It had a longer input shaft so instead of replacing the input shaft, my friend's shop has a CNC machine so he made a wider adapter plate between the trans and the bell housing.
Yes now that I really look at it you are correct its not a T5..Trans and bell are one piece..
749256
