Your timing cover will fit without any grief. Mine did. I am running the v-belts too.
You can use your existing radiator if you use your existing timing cover and water pump.
If you want to use the EFI you need to use the computer, which means you will need a distributor compatible with the computer. You can use an aftermarket coil, but not likely the one you have. Your plug wires will have to be replaced.
Your biggest issue will be getting a v-belt crank pulley that will line up with your existing stuff. I got mine from March. Call March and tell them what you are doing and they will tell you how to measure for proper fitment.
