OK fella's I was on the way home tonight with my girlfriend and my stang' cut out. I was cruising at about 60 and the engine cut out and I gave a little juice and it came back. Then a few down the road and it did the same thing only this time it totally died. I have had this problem randomly over the past several months and am sort of baffled.
I am fairly sure my fuel system is fine. I have a new gas tank, rebuilt the edelbrock 600 about 5 months ago. I regularly change my fuel filter and I changed it probably a month ago. (this is my daily driver f.y.i.)
Also, I have an older style distributer(non-points) with a mallory hyfire ignition box. The car always starts good. I am thinking maybe this ignition system is on the brink...not sure though.
When i pulled over after it died and put it in park the engine would not click/turn over. The headlights worked and were bright. I figured if it was a fuel problem it would atleast turn over and then die. Finally out of the blue she started right up. On the way home it acted like it was going to cut out a few more times.
ok last words...I have started it up in the morning or after work and driven maybe 5 miles and sitting at a stoplight it has just died and will start right up.
Now time for your thinking!
regards, Nick
regards, Nick
