checked out 2 66 fastback rollers tonight, 1 is a c code the other is a a code. both need total restos, have good roofs, the a code has the cowl done and good front frame rails. i could see the one rear rail is bad though it's poking through the trunk floor.
as for the c code it also has a good roof, couldn't crawl under to see it's bottom though.
i am unfamiliar with the early ones having dealt with all 67-68's since i got into the hobby. my question is what would these things be worth as rolling projects?
thanks
Selling $2500-$5000 on Ebay right now with or without engines/transmissions.
I try to keep my projects under 2k.
Hey, Russ! 66 FBs are the lowest production #s...go for it. Did you ever get your welding/rust repair done? Good luck.
ANY fastback title and vin plate is worth $1,000.00 (hey, I don't condone it, it is just a fact) If it has a complete interior it is worth at least $2,000.00 I would say that anything less than $2,500 for the pair would be a really good deal.
