Is there any marking on an original A-code engine that make it easy to distinguish from a C-code?
I seem to see a lot of C-coded cars with a 4V carb on it (some of which the owners state a factory 4v cars, yet the vin# shows 2v)
Other than the internal differences between the two, is there an easy way to externally distinguish the two? (You can't really pull apart the engine of a car that you are looking at, and data plates are easy to change as well as putting a 4V carb on it)
Thanks,
Eric
Nope..... differences are the intake, carb, and pistons ( I recently found this out here).
Sure, you can change dataplates, but if the inner fender on the drivers side is stamped, it is probably right. It would be a lot of work just to fake out a C code to an A code and IMHO the A code is still pretty common. If you where that evil a person you would probably just make it a K code.
TJ - Highland Village, TX (DFW area)
66 coupe 302 2v c4 -daily driver
94 GT vert -SWMBO's
93 Aerostar - hauling stuff
50 Mercury Pickup - waiting to be restored, stored back home
