I’m installing the vintage air unit into the 69 vert and questioning who has wired theirs up to an AAW harness. I’ve read in some Camaro forums of guys running the power to VA from AAW from the heater/ac wire, which is Wire #50 and fused at 30 amps. What I can’t find out is if they are keeping the inline fuse that is supplied or just use the fuse in the AAW kit.
anyone have experience with this?
68 Mustang Coupe
What's the rated amperage?
If wire #50 is fused with a 30A fuse, there is no reason to keep the VA inline fuse. It will make for a cleaner and easier to troubleshoot system. Are you using the AAW Classic Update kit? First gen or second gen?
Reactions: Boss5Oh
I ran mine direct from the fuse block and chucked the VA fuse (into my spare wire drawer anyway). No need to double fuse. The VA use of factory controls is pretty sweet- easy to install. (mine's a '66)
im going to assume its second gen as I bought it in late 2019.
thanks! do you remember what key on source you used?
Off hand, no. I’m thinking it was just the wire marked for a/c- brown maybe as I recall?...
