Is the clutch & brake pedal from a '69 different than '67-'68 model years?
Thanks,
Yes they are different, would they still work, probably. The 69 clutch pedal has a completely square shaped pad area on bottom (different from earlier years). It also has a different type of upper return spring -so the bracket up there is different (alot of people leave them off anyways). From what I could see of brake pedal, about the only difference is the 69 didn't seem to have a bracket up top that the 68 did, but it was shaped identical (bent like the 68 to clear wider column).
Thanks, :(
