1 - 10 of 10 Posts
Im thinking I have the wrong one.
The adjustable idler that was on my 65 289 AC with a 2 groove crank pulley is C5AA-8A619-B.
There is no way to shim that out 1/2in to match the new three grove crank pulley and 2 groove WP pulley required for PS.
SD sells an adjustable idler C5ZZ-8678-B. Is that the one I need and is it correct for a 65 with AC and PS?
Discussion Starter #2
Thinking about this all day.
I think my C5AA bracket is correct and the pulley is not correct.
There just isnt a way to push that bracket and pulley toward the radiator 1/2in.
The pulley presses on the bracket.
Can someone with a factory AC and PS car take the same measurement my pic shows?
Ive got 2.5in on my bracket/pulley.
Can you post pics of what you have? I just added factory style A/C to a 65 Fastback. I looked up all the correct matching parts and tracked them down. Everything lined up fine. It had an early 65 aluminum water pump. After 2 of those failed, I switched to a late 65 iron pump and timing cover. That required some changes to the hardware and spacers to line things back up again.
Unfortunately I am on the road or I would be able to give you a list of the correct parts.
Im pretty sure I have all the correct parts except for the adjustable idler.
I think my car originally didnt have AC and it was a dealer or owner add on. It is the correct Ford unit inside the car with a York Compressor.
Im going to need a adjustable idler like Bob posted.
Im so deep into this now................but its what I want.
Ever think of trying to find just the pulley with 1/2" more offset? Assuming it has a bearing in the center, eh? Another option, if it has a roller bearing center, is an offset bearing.
I will just buy the correct idler and save the one I have for a later project.
I will probably add AC to my 67. I have the 2 groove crank pulley, clutch and this idler, so Im well on my way to having the necessary parts.
The 67 will get EAPS, so Im not going through this nightmare again.
Once the 67 is well on its way Im going to give it to my SIL anyway, so its money well spent.
Discussion Starter #8
Flade, the only spacers Im using right now is the one on the lower groove of the idler and the two behind the AC pedestal. Those two come out when I put on the PS pump bracket.
I bought AMK F-492 WP bolt kit, it has a couple more spacers that I may need once I get the correct idler.
I also have the fixed idler and that looks like it will line up with the AC clutch and crank pulleys ok.
My PS pump bracket was bent, I put it on a press and straightened it out today, I should have it on the engine tomorrow along with the WP.
The WP has been on without the gasket while I worked on pulley alignment, but I think Ive got it figured out well enough to get things back together.
Reviving this thread as I am in a similar predicament.
I'm mounting AC on my 66 (289), and have concerns if I have the correct idler pulley, as well as where to mount it. (see pic of pulley that I got) -- it looks like the one that is shown in the first pic on Post #4, above.
I'm using a Sanden compressor mounted on what appears to be the original York plate (it came with the car, but not mounted, so I'm not exactly sure where it goes).
DOes this idler assembly line up OK for a Sanden replacement?
Thanks.
I use that same idler with my Sanden installation. I also use the adapter mount that bolts to the factory AC compressor mount. In the attached image, you can see the position of the idler on the left. You can also see the belt alignment in the forward position of the compressor pulley. Both align with the forward groove on the 3 belt crank pulley.
737336
1 - 10 of 10 Posts
