I would like to add power brakes but didn't know if there were any costs that I wasn't considering. What all do I need for the conversion? I already have front disc and need a new 9" rear(will probably have disc) and I have the dual master cylinder as well. I will be putting out some decent power and want to make sure that it can stop on a dime if need be.
considering you already have a dual master cylinder and disc brakes, the only thing you need to convert over to power brakes is the power booster. however, you will need either a proportioning valve or combo valve with discs. you may also need to rework your brake lines to the mc
I believe the pivot point on the brake pedal for power brakes is different than non-power. For my 67 it is, I purchased new pedal from Master Power Brakes.
