1 - 2 of 2 Posts
these valves listed in all books and summit. do they go in place of the current valves. my buddy added a granada disc/drum but its bad/old and dried up.does this adj. valve have the hookups,5, for all brake/master cyc. lines. for some reason i thought all it did was go in the rear brake line only. so ive been feeding a little wrong info.im thinking a good replacement now is the adj. type,right. thanks
From what I have seen, the front goes fron the MC to a "spliter" or "metering valve" and then to the front brakes.
The rear "can" go fron the master cylinder to the adj valve to the rear.
Check out the tech info of mpbrakes.com for some good info
1 - 2 of 2 Posts
