On my '66 I have Granada front discs and Versailles rear discs with a Wilwood MC (260-8555). My brake pedal sits about 1-inch lower than my clutch pedal and if I pull it up then when it hits the pedal stop it's parallel with the clutch pedal. Since I have manual 4-way discs, I bought the Scott Drake A21161-DB adjustable brake pedal rod which lowers the pedal mounting point. Well this part is pushing into the MC at an angle and binds terribly with my Wilwood MC. It initially bound on the brake light switch until I shimmed it with washers. It comes with no instructions or diagram and so I'm just wondering if anyone has had luck with this adjustable brake rod and the Wilwood MC? I think I'm just going to return this dropped mount version and make my stock '66 Mustang rod into an adjustable one by cutting in half and using a die.
CJPony A21161-DB
Thanks!
CJPony A21161-DB
Thanks!
