the steering in my 69 has a little play int he wheel, i was wondering if there is an adjustment for that???? the car has factory power steering.
How old is your steering box?
:eek: you know, I've never looked at my steering box but I hope it has the same setup as some of the later Fords where it has an adjustment screw on top.....but my luck says probably not.
have someone turn the steering wheel back and forth through the "play". and watch each portion of the steering linkage from the shaft to the rag joint to the steering box input to the... (so on and so on...) You will find the portion of the system where the play is introduced. The play in my steering (manual) turned out to be everything but the box.
