I'm about to buy new rubber for my clutch/brake/gas pedals, and I was wondering if any of you can recommend an aftermarket pedal kit, polished stainless steel or the like. I asked this question once before on the old forum, but I can't find it :) What are you guys using?
Thespazardman
I've had to glue on the repro clutch rubber pedals to the metal pedal. Otherwise, it slips off at the most inopportune moments. *G*
http://clubs.hemmings.com/baymustang/platesmall.jpgLet me check your shorts! My multimeter is just a-waiting! Formerly known as Midlife in the old VMF.
King of the Old Farts *struts*
Supporting Vendor
I had to use supper trim glue on the clutch also. I run open track events with
the Shelby club and use the stock pedal set. If you have big feet like I do,
the bigger pedals just get in the way. I can heal-toe with the stock set up
just fine. That is the reason people go to the aftermarket stuff, other than
the looks.
