I have 2 1965 cars that need alignments,1 car is has a stock front end suspension in it,the 2nd.one has the shelby drop,front coils are cut to lower it and I installed the Dr.Gas lower control ecentric kit in it,would they have the same specs or is there a site I can print out to give the alignment shop,thanks,Pete
Same specs for both, unless you want one to be more agressive then the other.
STREET SPECS *
Caster: +1.5° to +2.5°
Camber: 0 to -.5°
Toe: 1/8" in
STREET/PERFORMANCE *
Caster: +2.0° to +3.0°
Camber: -.5° to -1.5°
Toe: 1/8" in
I've done my own alignments with a gauge(Fastrax) I got from Summitt Racing. Paid for itself aleady. Did my 65 w/ shelby drop, daughter's 66 with shelby drop and cut coils, son's 68 with shelby drop and cut coils, and a friends 70.
STREET SPECS *
Camber: 0 to -.5°
Toe: 1/8" in
Toe: 1/8" in
Yes. All of that. Yes.
The caster makes the steering much more stable at high speeds. The camber will make it corner better, but the trade off here is a little bit faster tire wear. 1 degree probably won't make too much of a difference in tire wear, though.
I had my car aligned to:
Caster: +3.0 degrees
Camber: 0
Toe-in: 1/8"
LOVE it.
-Matt
