how bad are these alignment specs?
caster + 2.0 caster +.6
camber -.5 camber -.5
tow in 1 1/16th in.
the shop said they couldnt get more caster on one side? is there a probably cause for that? could i have a bent rod or something?
Steve Stiles
As you suspect, everything looks pretty good except the caster. Did he tell you why he thought he couldn't get more caster on one side - worn parts, bent unibody?
he said he was out of adjustment. on caster? whatever that means technicly? ..then when i persisted on exactly what component was bent? or not even NEW he suggested a possible bent frame? if indeed that is the case, would i be better off with the caster being +.6 on both sides instead of +2 and +.6 ? or should i leave it alone? he said it doesnt pull to the right. guess i will find out in the morning.
Steve
Toe-in should be 1/16-1/8 inches, not 1 1/16. Maybe that why it doesn't pull. How is the tire wear?
Discussion Starter · #6 ·
Steve,
We need some bio information on you and your car. I know two wizard alignment shops in Southern California that really know their vintage Mustangs. Where are you?
